Author Topic: RNS Retrofit - Satellites  (Read 2959 times)
Offline Adycakes
« on: 14 January 2015, 21:54 »
Hi guys,
I've just retrofitted an RNS-510 to my Golf but on checking the GPS Viewer the most Satellites it finds is 5 - 6 out of 10. Should I be worried? Is this normal? I should add that the map updates & navigation works just fine.
Any advice would be appreciated, thanks.
Offline golfhappy
Re: RNS Retrofit - Satellites
« Reply #1 on: 14 January 2015, 22:27 »
As long as the satellites ain't Russian or North Korean it should be ok!! Sorry i couldn't help myself, it's my sense of humour  :smiley:
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline Adycakes
« Reply #2 on: 14 January 2015, 23:19 »
Ha Ha! Not sure I'll know if they're Russian or North Korean though! ;)
Offline Buck
  • Das Auto
« Reply #3 on: 15 January 2015, 00:18 »
When I've checked mine the most it has ever latched onto is 7 - if it can get 3 or more you are fine as it can then triangulate your position and plot on the Nav.
A little while ago mine could only locate 2 for some reason and my car was driving across no man's land for quite a few miles!
Offline Adycakes
« Reply #4 on: 15 January 2015, 10:25 »
Mine doesn't seem to drop below 5, so I'm hoping it's going to be ok. Thanks for replying though, I do appreciate it!
Offline Mark V GTD
« Reply #5 on: 21 January 2015, 12:39 »
Sounds normal to me - so long as you are getting a 3d view you will be fine :-)
