Author Topic: tyre pressures  (Read 2144 times)
Offline martinc1967
tyre pressures
« on: 12 January 2015, 12:54 »
Checked my tyre pressures yesterday and on the petrol flap it stated 38psi unloaded. Is that correct or am I missing something?
Seems high to me?
Regards,
Mart
Offline Booth11
Re: tyre pressures
« Reply #1 on: 12 January 2015, 15:18 »
38psi sounds right for 18", though the info on the fuel flap has been known to differ from car to car :whistle:
I have 19" and my recommended is 41psi min load 44psi max load
Bit more info here or there's other threads if you do a search http://www.golfgtiforum.co.uk/index.php?topic=262606.msg2413392#msg2413392
« Last Edit: 12 January 2015, 15:26 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline dubber36
Re: tyre pressures
« Reply #2 on: 12 January 2015, 16:27 »
Cars are pretty heavy so need higher tyre pressures to support their weight. Manufactures also recommend higher pressures as a way of reducing fuel consumption figures.
My GT TDI should be 2.4 bar/35psi according to the sticker, so depending on the spec your cars has, 38psi sounds about right, although I'd set them a smidge lower to improve the ride and cold/wet road grip levels.
Offline Snooze
Re: tyre pressures
« Reply #3 on: 12 January 2015, 18:11 »
38 psi is correct for 18" Monza's
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline martinc1967
Re: tyre pressures
« Reply #4 on: 13 January 2015, 12:55 »
Thanks guys
