Author Topic: will 18x8jj et35 255 tyres fit the rear of my car  (Read 3195 times)
Offline gavsgti
« on: 11 January 2015, 21:34 »
i recently bought a set of alloys which was advertised as been for a golf mk 4 but was wondering if there actually going to fit
fronts are 225/40/18 and rears are 255/35/18 ET35
was also wondering what size spacers i will need car will be lowered on adjustables so ride hieght can vary
not sure if im posting in right place sorry if im not
thanks in advance for your help
gav
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: will 18x8jj et35 255 tyres fit the rear of my car
« Reply #1 on: 11 January 2015, 21:39 »
rear tyres are way off what you need mate. Just get some 225/40s on there. As for spacers I run 15mm rear with 8mm up front on a set of 18x8s and the faces are pretty much in line with the arch
You had a look to see if they physically fit on the hubs?
Offline gavsgti
« Reply #2 on: 11 January 2015, 21:46 »
not yet as my cars in garage atm with the boot not opening plus getting adjustable suspension and brakes fit lol
was advertised as 5x100 which from what i researched was same fitment as the mk4s they do have audi centre caps atm
the guy i bought that off had a golf mk4 and said he had bought them for his car but then decided he wanted to sell his car
wheels are badly kerbed atm so im going to have a go at refubing before i fit them plus think this put him off putting them on but can never be sure
thanks for the reply ;)
« Reply #3 on: 12 January 2015, 22:08 »
I would check they are 100% 5 x100 as a first step.
Offline gavsgti
« Reply #4 on: 12 January 2015, 22:57 »
aye gunna do when i get car back tho is it poss to measure them ?
thxs for reply ;)
Offline gavsgti
« Reply #5 on: 12 January 2015, 23:17 »
can they be measured with a digital caliper as i have one ?
« Reply #6 on: 12 January 2015, 23:31 »
Well if they are stamped et35 then see what other markings you can find
Offline gavsgti
« Reply #7 on: 13 January 2015, 17:52 »
all the markings ive found are:-
ET35
R210
07+++++
08+++++
18x8jj
60psi
via690kg
nothing saying 5x100 or 5x112
not a clue what all these mean lol
Offline viperjsy
« Reply #8 on: 23 January 2015, 04:35 »
you can mesure where the line is where I have marked in pic that will give you the pcd
