Author Topic: fuel leak...and its not the first!  (Read 2765 times)
Offline rallypug
« on: 10 January 2015, 15:39 »
Just discovered a fuel leak on the fuel pressure regulator (under bonnet, right hand side of cylinder head) on my gti (mk7, 20,000 miles) . Already had a fuel tank access hatch leak..(12,000 miles)... Just wondering if anyone else has had the same ??
Not happy !
5 Door, Manual,  Perf Pack, Tornado Red, Winter Pack, Adaptive Chassis, Sat Nav ....
Offline GeoBog
Re: fuel leak...and its not the first!
« Reply #1 on: 11 January 2015, 20:24 »
Have a look on the international mk7 forum as there seems to be a problem and a VW recall with a fuel leak on US cars. You might be experiencing the same issue as well.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline lockhart
« Reply #2 on: 12 January 2015, 11:56 »
I had a fuel leak at that regulator.. this was replaced and then started a whole load of issues with the car eventually being rejected after the HPFP failed sticking injectors open with metal shavings (so I am told!but don't believe!)
Offline rallypug
« Reply #3 on: 12 January 2015, 20:33 »
Thanks for the info...update from the dealers...it wasn't the regulator but the high pressure fuel pump,  this is going to be replaced... I wait to see the consequences of it's failure !
