Author Topic: Bam ko4 conversion -inlet manifold  (Read 2099 times)
Offline Sidewayssam
« on: 08 January 2015, 17:00 »
Hi guys I'm new on hee looking for a bit of advice so here goes I've bought a full ko4-23 bam conversion for my golf auq can fit it nae probs but only issue is I've noticed the throttle body is located on the other side of the inlet manifold compared to yhe 1 on the golf is there a simple way round this or is it a really technical thing or can I just fit bigger 440 cc injectors to the auq inlet manifold, car is standard golf Gti 180 at the moment any help would be greatly appreciated thanks
Offline MoMartin
Re: Bam ko4 conversion -inlet manifold
« Reply #1 on: 10 January 2015, 16:48 »
I think that its a bolt on fit and the only thing you might have to change is the pipe work that connects to the top of it / extend wires (for the iat sensor?)
i've heard of a few people who have done this for the sake of adding a fmic, as it means that you can keep the stock pipework from the turbo straight to the front of the car + a few additional pipes to connect the other side of fmic to the inlet.
Also, remember to keep the upgraded injectors / 3" maf out of the car until it comes to remapping.
hope this helps.
Offline Sidewayssam
« Reply #2 on: 11 January 2015, 03:52 »
Kool cheers thanks for the reply  :cool:
