Author Topic: Boost and vacuum pressure on my aum  (Read 2030 times)
Offline reedy20vturbo
« on: 07 January 2015, 20:17 »
Hello, I've recently fitted a boost gauge and am wondering what the average boost levels and vacuum levels are on the aum?  I always get 9 psi when booted until about 5k and it slowly dies down can't remember my vacuum level, just wanted to know what others are getting, cheers
Offline brewey
Re: Boost and vacuum pressure on my aum
« Reply #1 on: 07 January 2015, 22:37 »
If your car is standard (map wise) which I'm guessing it is then that's what is expected. In terms of vacuum you should see a reading anywhere between 20-25.
2000 1.8T ARZ - OEM+
« Reply #2 on: 07 January 2015, 23:20 »
It is standard mate, Im getting 30 at idle that must mean I have a vac leak somewhere?
Offline brewey
« Reply #3 on: 07 January 2015, 23:32 »
No if you had a vac leak then the needle would be bouncing between numbers not just sitting at 30.
