Author Topic: spec sheet from new  (Read 5174 times)
sus
spec sheet from new
« on: 07 January 2015, 13:28 »
hi is there anyway of getting a spec from new list od my car its a 2012 gtd
Offline Organisys
  • Old and Slow...
Re: spec sheet from new
« Reply #1 on: 07 January 2015, 13:33 »
If you make a note of the VIN and write to VW customer services UK, then yes they should be able to help. You could try a dealer first although they are sometimes not as *helpfull*
Offline Booth11
« Reply #2 on: 07 January 2015, 13:46 »
You could give this a go, though it appears to have been updated last in 2012.
Somewhere in the boot there should be the specification/service sticker listing all the spec codes (probably around the spare wheel well).  If you type all the codes into the VAG decoder below, seperated by a semi colon and press decode, it should tell you what you've got.
http://igorweb.org/equidec/Default.aspx
« Last Edit: 07 January 2015, 14:01 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
sus
« Reply #3 on: 07 January 2015, 15:32 »
thanks will have a look
Offline seabrook132
« Reply #4 on: 07 January 2015, 16:20 »
Just seen your pic in the other thread, looks like a lovely GTD you got there! Pretty rare to see one on Khartoum wheels too, I think they're a VW accessory rather than factory fit so I guess it would've left the factory with something else? Either way they look good  :smiley:.
Is the number plate personal or is your username based off the plate? :huh:
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline J400uk
« Reply #5 on: 07 January 2015, 18:54 »
If its just the general standard spec for a 2012 GTD you're after then look here - http://www.volkswagen.co.uk/assets/common/pdf/pricelists/golf-vi-pricelist.pdf
2015 Golf GTD 2.0 TDI 184 PS 6-speed DSG 5 Door Tornado Red
sus
« Reply #6 on: 07 January 2015, 18:59 »
some of the sticker is ripped off but got this
B0N = Component parts set, complying with vehicle type for Great Britain, various parts
CV1 = Alloy wheels 7.5J x 18
G1 = code not found :-(
H7D = Tires 225/40 R18 92Y xl
J1D = Battery 380 A (72 Ah)
D93 = 4-cyl. turbo dies. eng. 2.0 l/125 kW 4V TDI common rail Base engine is TG3/TH3/TL4/TM4/TP4/TU3
1AT = Electronic stabilization program (ESP)
1G9 = Space-saving spare wheel for temporary use, radial tire (5-hole)
2FU = Leather trimmed multi-function sports steering wheel w/ Tiptronic
1NL = Covers for alloy wheels
5RV = Right exterior mirror: aspherical
5SJ = Left exterior mirror: convex
TL4 = 4-cylinder diesel engine 2.0 l unit 03L.L
0BM = Rear stabilizer
3UI = Seat preparation SCS
Q01 = Suspension range 301
8AY = Radio/navigation system
anyone know what wheels are code CV1 ??
Offline Booth11
« Reply #7 on: 07 January 2015, 19:09 »
If you've got the original car manual/handbook, the same spec sticker is usually just inside the front cover.  Sorry don't know about the alloy code.
Seen your car in the photo thread - lovely looking GTD  :cool:
« Last Edit: 07 January 2015, 19:11 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
sus
« Reply #8 on: 07 January 2015, 19:29 »
thanks just looked and its inside cover of service history
sus
« Reply #9 on: 07 January 2015, 19:37 »
right got full codes from sticker in service book
G1A = 6-speed automatic transmission
3U1 = Foldable trunk cover
QG1 = Service interval prolongation
8GU = Alternator 140 A
8ZH = Antenna for AM/FM reception, "diversity"
1KD = Disc brakes, rear
1ZA = Disc brakes, front
G58 = Front shock absorption
7MG = Emission standard EU5
0Y1 = Standard climatic zones
4UP = Drivers and front passenger air bag with knee air bag and front passenger air bag deactivation
4X3 = Side air bag front with curtain air bag
4R4 = Power windows with comfort operation andcircuit breaker
4K3 = Radio remote controlled central locking operated from inside and safe securing
N7F = Partially leather seat covering, fine embossed
5MD = Decorative aluminum inserts
8RM = 8 speakers (passive)
2JQ = Sports bumpers
E0A = No special edition
0AE = Front stabilizer
2VC = Nameplate set "V8 4.2"
2G5 = Filler neck module 1 without insert
1JN = Rear shock absorption
L59 = Suspension range 59 installation control only, no requirement forecast
0YC = Weight range 3 installation control only, no requirement forecast
