Author Topic: Help needed-guide to replace horn ring  (Read 2077 times)
Offline Jasikasisback
« on: 04 January 2015, 07:28 »
Hi I need a guide to replace the horn ring in the steering wheel....any help appreciated
Re: Help needed-guide to replace horn ring
« Reply #1 on: 04 January 2015, 07:31 »
please mention what tools are needed and how to remove the steering wheel..if I have to do that....
Offline itavaltalainen
« Reply #2 on: 04 January 2015, 13:15 »
Put wheels straight
With airbag undo the 2 allen bolt on back of wheel (iirc 4 or 5mm, might need to remove column trim for access)
then take airbag off (unplug connector) and place front down in the boot (I assume you know that you need to disconnect battery, then turn ignition on and wait for a minute before taking airbag off).
MARK THE POSITION OF THE STEERING WHEEL with white permanent marker.
Undo the nut (24mm socket)...
off it comes
« Reply #3 on: 17 January 2015, 21:03 »
Will give it a go.....:)
