Author Topic: RNS510 poor radio  (Read 3242 times)
Offline DY59
RNS510 poor radio
« on: 01 January 2015, 20:01 »
Hi having some problems with my rns510.. i used to have a rcd310 so thought it would be a straight swap.
I'm getting very poor FM signal and both ant are off
Many thanks
Here are the fault codes
Thursday,01,January,2015,19:06:45:35429
VCDS Version: Release 14.10.0
Address 56: Radio Labels: 1T0-035-680.clb
Control Module Part Number: 1T0 035 680 P HW: 1T0 035 680 P
Component and/or Version: RNS-MID H10 5274
Software Coding: 06060002040000810000
Work Shop Code: WSC 50225 001 104857
VCID: 3B751A18BAEFC5F97A9-806E
4 Faults Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 58192 km
Time Indication: 0
00856 - Radio Antenna
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 2
Reset counter: 242
Mileage: 58192 km
Time Indication: 0
00821 - Antenna 2 for Radio (R93)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 58192 km
Time Indication: 0
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 58194 km
Time Indication: 0
Date: 2060.14.18
Time: 19:04:25
Offline th3_f15t
Re: RNS510 poor radio
« Reply #1 on: 02 January 2015, 10:10 »
Check the wires into the harness which plugs into the back of your unit, also check the pins in the unit as well. Could be a few faulty/damaged connections. I think there's wiring diagrams in the Haynes manual to help isolate specific wires for each item (power, signals ect.).
Electrical faults suck, wish you luck!
Moving over to Flickr, sorry for the broken picture links!
Offline DY59
« Reply #2 on: 02 January 2015, 11:15 »
Hi. It's not the cd changer that Troubles me it's the poor signal I get on the radio.  Could they be linked ?
Offline th3_f15t
« Reply #3 on: 02 January 2015, 14:42 »
Possibly, my Kenwood unit has to have an additional power feed to the aerial booster unit, you may have a similar think with your stereo but I've never worked with one so unsure.
