Author Topic: New owner!  (Read 5766 times)
Offline spursman
New owner!
« on: 01 January 2015, 17:38 »
Hi,
Happy New Year!
Be gentle, first time poster and new owner of a Golf GTI! (230, PP)
Absolutely love the car. Bought an ex-demo and it's in very good condition. Just over 3000 miles on the clock.
I've mainly been on short journeys - is the mpg in the linked pic to be expected or is it a little low? Appreciate this is just a short journey, but wanted to make sure the figures look ok. Appreciate your thoughts.
Thanks!
Golf GTI PP, Carbon Grey, DSG, Nav Pro, DCC, Park Assist, Dynaudio, Santiagos, Winter Pack, Keyless
Offline monkeyhanger
Re: New owner!
« Reply #1 on: 01 January 2015, 17:47 »
On a 4 mile journey with the oil perhaps not even cracking 50C, that's fine. If you'd been on a journey 10+ miles you'd have probably been into the low 30s.
Re: New owner!
« Reply #2 on: 01 January 2015, 17:50 »
Happy new year to all, haven't been near my car for a few days, sat in Coco's outback pub in Amsterdam (as I was for seeing in New Year).
Offline spursman
Re: New owner!
« Reply #3 on: 01 January 2015, 22:57 »
Thanks. after 8 miles the mpg is up to 28. Looking at the long-term stats the previous 1000 miles averaged 29mpg. If that's in the ballpark then I'm happy. Is it true the running in of the car has a long-term impact on achieved mpg?
Appreciate your help.
Re: New owner!
« Reply #4 on: 02 January 2015, 09:31 »
I've run in one new VW not ideally (on my 7th new one) and it's been thirsty for both oil and fuel. Keep an eye on the oil (if it only needs a litre every 5000 miles at most, maybe not even needing any between services then you're doing fine). On a 15+ mile journey you should be doing 32mpg if you don't hammer it. The car will only be around 2/3 efficient until warm.
Offline spursman
Re: New owner!
« Reply #5 on: 02 January 2015, 09:44 »
Thanks.
I guess the problem with buying demo is that the vw rep is unlikely to run it in gently. Am I right in saying that with these modern engines the run-in is less of an issue?
Are you concerned with the 29mg over 1000 miles? The car had averaged 36mpg on a 200 mile journey that was mainly motorways.
So should i regularly be dipping the oil?
Re: New owner!
« Reply #6 on: 02 January 2015, 09:50 »
Once a week check for the oil is fine, once the engine has cooled and on a level surface. Is say banging the engine is worse than giving it a bit of a work out once warm. 36mpg on a 200mile motorway journey could be considered ok depending on how it got there. Doing 75/80 all the way in winter you've done well. If it did 36mpg doing 60mph over 200 miles in the summer then that's poor.
Offline Jimble
  • Moderator
Re: New owner!
« Reply #7 on: 02 January 2015, 11:34 »
I noticed you've got it set to ECO in your picture, in my experience that mode isn't always the most economical strangely, try running it in normal for a bit and see if it improves? Tbh though 29mpg isn't bad going round town.
Offline caprigreen
Re: New owner!
« Reply #8 on: 02 January 2015, 20:20 »
I have just clocked up my first 1000 miles. I averages 40 mpg on the 300 miles trip back from the dealer taking it very steady and varying the revs. Since I got home I have averaged 31 mpg for 700 miles with mainly short 6 mile trips. Not sure if this will improve , I am happy with 30 mpg  as only do around 8k miles a year  :smiley:
64 plate VW Golf GTI PP Pure white
1991 VW Golf GTI 8v Silver, 30k miles
Offline spursman
Re: New owner!
« Reply #9 on: 02 January 2015, 22:12 »
Interesting about ECO v normal.
Caprigreen - what mode have you been using.
Will give it a try over the weekend.
But I'm definitely not going to lose sleep over 2-3mpg :)
I doubt my car has had the best run in but hopefully my careful maintenance will improve things.
