Author Topic: K04 setup on AGU  (Read 6015 times)
Offline MoMartin
K04 setup on AGU
« on: 28 December 2014, 14:41 »
Hi, I've been looking into turbo options for my AGU and have found that a k04 to k03/s downpipe adapter is available. This adapter should cut the cost / hassle of the k04 upgrade, but it has also made me wonder what else would be needed.
Starting from the top - I have a stage 2 K03 AGU (fmic, pipercross filter, decat / 3" downpipe, Forge 007p)
I'll also be needing these mods:
Fuel injectors
3" maf / TIP
and a 3 or 5 Bar fuel pressure regulator(?)
k04 turbo (with oil feeds?)
k03/s to k04 adapter -
Is there anything else that i have missed and does this k04 adapter look like a good buy?
Thanks in advance.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: K04 setup on AGU
« Reply #1 on: 28 December 2014, 17:47 »
How much does that pipe cost?
Offline MoMartin
« Reply #2 on: 28 December 2014, 20:23 »
£100
Edit - will I need the k04 charge pipe too?
« Last Edit: 28 December 2014, 22:05 by MoMartin »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 28 December 2014, 22:37 »
where from???
Offline MoMartin
« Reply #4 on: 29 December 2014, 00:11 »
Sorry for being vague haha, a guy on the vag cars / car parts Facebook group has started producing them.
The post always seems to dissapear whenever I go to look at it, but the guy seems to post it quite frequently.
The link to the Facebook group is -
https://m.facebook.com/groups/187261941322250?ref=bookmark
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 29 December 2014, 09:44 »
Bah I don't have Facebook...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 29 December 2014, 11:44 »
The easiest way IMO would be to have the outlet of the K04 cut and shut with a K03 as beach buggy turbos do. The only thing you'd have to look into then would be the TIP
Offline MoMartin
« Reply #7 on: 29 December 2014, 12:09 »
That's a shame and when you say all I need is a tip, what about the 3" maf, injectors and the fuel pressure regulator?
Surely those are still required too?
Edit -  found the adapter on ebay
http://pages.ebay.com/link/?nav=item.view&id=281540032742&globalID=EBAY-GB&alt=web
« Last Edit: 29 December 2014, 12:45 by MoMartin »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 29 December 2014, 14:43 »
Sorry I meant as a bolt on turbo, wasn't including hardware like the injectors etc. As a rule you'll need whatever came on the K04 equipped cars, you won't need a 4bar FPR unless you go for a Revo map though
Offline MoMartin
« Reply #9 on: 29 December 2014, 15:32 »
Ah okay thanks, just out of interest, why would it only be needed with a revo map? Do they tune it to a higher spec or something?
