Author Topic: Coolant system loosing fluid ... Help please  (Read 2006 times)
Offline Godinton
« on: 26 December 2014, 15:09 »
Hi,
I have a Golf MK5 GT sport that is loosing coolant. It is a very slow loss so is causing me trouble to find! Essentially from maximum line it goes below the minimum and triggers the sensor alert between 30 minutes and 1 hr of driving.
I have filled it and left it running for 20 minutes but it was not dripping and the level did not reduce that much. any suggestions to fault find or fix this issue?
Offline itavaltalainen
Re: Coolant system loosing fluid ... Help please
« Reply #1 on: 28 December 2014, 11:53 »
Add a bottle of coolant UV tracer and get a battery operated "black" light.... and you should find the leak, unless it's head gasket.
VW BUSH
« Reply #2 on: 28 December 2014, 14:59 »
Have you checked the oil for sludge/mayo?
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 29 December 2014, 15:50 »
Take a quick read of this thread, you might find it useful:
http://www.golfgtiforum.co.uk/index.php?topic=100997.msg858238#msg858238
