Author Topic: Aum oil catch can instalation  (Read 3016 times)
Offline reedy20vturbo
« on: 23 December 2014, 23:30 »
Hello all!
Looking at installing an oil catch can,  just wondering what's the most common successful way of doing this on an aum?
Offline rockmonkey69
Re: Aum oil catch can instalation
« Reply #1 on: 24 December 2014, 00:28 »
Not sure about most successful - that depends on the individual's requirements - so each setup will vary. The most common setup would probably involve routing the crankcase and valve cover breathers to a t-piece using rubber oil lines, this then feeds into a catch can mounted to the battery cover/slam panel/bulkhead and plumbed back into the turbo intake pipe.
I've played about with various different setups, now I've just stuck with the simplest design to meet my needs of a robust setup with minimal restriction to blow-by gases at high rpm usage.
« Reply #2 on: 24 December 2014, 08:50 »
Ideal ok mate thanks for the reply, will this stop the oil going back into the tip because it's being caught in the can?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 24 December 2014, 09:21 »
The oil vapour from the engine will condense when it goes through the catch can as long as you get a decent one with material in there. A lot of cheap cans only rely on the vapour hitting the walls of the can which isn't very efficient IMO
« Reply #4 on: 24 December 2014, 10:06 »
Ahh right ok, so what would you say a decent can was?
« Reply #5 on: 24 December 2014, 13:26 »
Some members rate the saikou michi catch can highly, not tried it myself though
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 24 December 2014, 15:40 »
I have the Saikou Michi can and it does what it says on the tin
Offline ap_gt3
« Reply #7 on: 28 December 2014, 12:32 »
Ive moved the pair of relays at the back in with the loom, and stuck the can there. Seems to be doing the job
Golf mk4 AUM... fmic, custom exhaust, 3" dp/decat, bbt actuator, s3 injectors, LCR fuel pump, sfs supersize tip, jetex filter, g60/vr6 clutch, badger 5 remap : 232.5 bhp / 242.3 lbft
Offline viperjsy
« Reply #8 on: 06 January 2015, 15:33 »
I am using this
it is doing a good job
here is a pic of it striped
here is a ebay link to the catch can
http://www.ebay.co.uk/itm/201095229012?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D201095229012%26_rdc%3D1
« Last Edit: 06 January 2015, 15:36 by viperjsy »
