Author Topic: Car spins up with ease  (Read 7684 times)
Offline MoMartin
Re: Car spins up with ease
« Reply #10 on: 11 December 2014, 19:01 »
Yeah I kind of wish i had a higher up power band now, because now that i live in Manchester, basically all the power my car has just cant be used  :angry:
thankfully I don't get these issues  :whistle:
Have you done any handling modifications?
Offline barrym381
« Reply #11 on: 11 December 2014, 19:46 »
car has a few but the 4 motion bit helps most  :smiley:
Offline rockmonkey69
« Reply #12 on: 11 December 2014, 20:21 »
4-motion would be nice, I got my sights set 4motion, even with my suspension setup it's struggling to put the power down.
« Last Edit: 11 December 2014, 20:47 by rockmonkey69 »
Offline MoMartin
« Reply #13 on: 11 December 2014, 20:22 »
I was gonna ask if it was a 4motion, but then i thought maybe you were just saying that your car just didn't wheelspin in the wet, and that our cars had a problem :grin:
Offline barrym381
« Reply #14 on: 11 December 2014, 20:56 »
yes with the ko4 its ok and its been the longest i have kept a car  :smiley:
« Reply #15 on: 11 December 2014, 21:13 »
I don't think I'll get wheel spin off the line with haldex, I'm wondering whether it would spin up at the top end when the turbo comes alive. What I'm thinking is, it'll be a hell of a lot better than fwd and I've seen that the haldex system can be made permanent 4wd and more torque sent to the rear than oem - using an aftermarket haldex controller. It's all very appealing but does mean I have to go through the effort of buying another LSD for the 02m unless the Quaife diff from the 02j is compatible with the 5 speed 4wd gearbox.
Offline barrym381
« Reply #16 on: 11 December 2014, 21:16 »
mine will still spin for a split second on full power but it has a 4motion controller and when i change the setting it wont spin even on full throttle and with kw3 coilovers its like glue until you strip the tyres  :grin:
« Reply #17 on: 11 December 2014, 21:50 »
Do you not keep haldex in permanent 4wd mode all the time? I worry how reliable the haldex system would be when left permanently engaged on a big turbo setup
Offline barrym381
« Reply #18 on: 11 December 2014, 23:10 »
no its left off nearly all the time  :whistle:
http://s1210.photobucket.com/user/barrym381/media/IMG_1058_zpsaa9f398e.mp4.html
Offline Dalo Harkin
« Reply #19 on: 16 December 2014, 12:52 »
I run Avons on the fronts because of this issue, I need to get the power down gradually
