Author Topic: Check Coolant Error  (Read 2598 times)
Offline marting
Check Coolant Error
« on: 11 December 2014, 11:30 »
I get an error, Check Coolant, appear when I turn the ignition on in the morning.  This only happens when the temp outside is lower than 3C.  Is anyone else experiencing this?  If so, is it a take it back to the dealers job?
Funnily enough I had this problem with my Mk5 and the dealers never got to the bottom of it.
On order: 5 dr, Manual, Carbon Grey GTD : Winter Pack : Dynaudio : Pro Nav : Rearview Camera
Offline fredgroves
Re: Check Coolant Error
« Reply #1 on: 11 December 2014, 12:02 »
Its not that at 3 degrees or lower the coolant has contracted under low temp to below the sensor level?
Have you checked the coolant level? Could be marginal?
Offline marting
« Reply #2 on: 11 December 2014, 14:31 »
Could be a good call. Seems ok now but Ill check it out in the morning before I start it up.
Offline corgi
« Reply #3 on: 11 December 2014, 14:46 »
Except that water is at its most dense (i.e. contracted) at 4C and is less dense at 3C... this is why ice floats... However, because there is not only water in the system, you could be right...
Corgi
Offline mcmaddy
« Reply #4 on: 11 December 2014, 17:52 »
Do vw still use water based fluids for coolant systems?
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 11 December 2014, 19:39 »
i see this all the time on various VAG motors, in my own cars too but never in a car so new that corrosion on the sensor prongs is virtually impossible. VW will probably want to replicate the fault meaning you'll be without the car for a couple of days probably and if you're lucky you'll get a new coolant reservoir fitted F.O.C.
Offline marting
« Reply #6 on: 12 December 2014, 10:19 »
Yes, you are right, VW want the car for a few days to check it out.  Its going in next week.
