Author Topic: 1.8T Coolant Leak  (Read 1970 times)
Offline Scott D
1.8T Coolant Leak
« on: 07 December 2014, 15:40 »
Got a coolant leak on my 1.8T AUQ engine.
I have already changed the coolant temp sensor housing, gasket, lower pipe and replaced all the c-clips. It seems to be leaking from around where the SAI combi valve is located and only leaks when revving the engine above 3000rpm.
Had a good look around the area but without taking parts off not able to identify source of leak. Is there any other common areas where it might be coming from?
Thanks
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
