Author Topic: Entire suspension swap  (Read 1635 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 27 November 2014, 20:43 »
Hi,
So, I have decided to totally change out my entire suspension system, all of the bushes, new shocks, new springs, new wishbones, ball joint, track rod ends and rear beam bushes...
I am considering dealing with the brakes while I am there...A few questions...
Should I replace the entire hubs while I'm there, or will these be OK?
Should I replace all of the wheel bearings while I'm there?
Anything else I should be aware of?
Simple questions I know, but I've been building up the pieces slowly to do it all in a oner then get it trackeddd
 :smiley:
Offline andy68
Re: Entire suspension swap
« Reply #1 on: 28 November 2014, 12:07 »
hubs should be fine, new bearings ain't a bad idea if the car is in bits and up on miles
Offline scarr89
« Reply #2 on: 28 November 2014, 15:40 »
Milage is up for sure, and I've not changed them in 3 years.
http://www.eurocarparts.com/wheel-bearing-and-wheel-hub
There are 2 typres on here, anyone know which one I am after?  :shocked: :undecided:
