Author Topic: More Problems  (Read 19138 times)
Offline itavaltalainen
Re: More Problems
« Reply #10 on: 11 December 2014, 18:09 »
Strange VW UK have not heard of ignition switch issues that showed the same symptoms on quite a number of cars in Germany, where VW has authorised their replacement.
They wanna change the complete steering rack?? Suppose that includes the igntion switch as it's mounted on the steering column (at least was there on previous models).
Good luck, hope they'll sort it soon....
Offline corgi
Re: More Problems
« Reply #11 on: 12 December 2014, 11:20 »
Is the column part of the rack assembly? Changing the steering rack relatively simple... changing the column, significantly more effort...
Corgi
Offline topher
  • Administrator
  • fully functioning
Re: More Problems
« Reply #12 on: 12 December 2014, 19:22 »
do you know what the actual fault code and description is?
Offline hastd2
  • Gti the Ultimate Hot Hatch...
Re: More Problems
« Reply #13 on: 15 December 2014, 12:19 »
You cant make this sh%t up......
Todays report
Morning Doug,
We do indeed have some progress but not in the direction we were heading last week!
On completing the wiring checks as agreed with technical department it would appear the conversation our tech had with them last week has resulted in them further investigating within the Volkswagen group the suggestion you emailed from the internet of the ignition switch being the issue.
Technical team have clearly found similar issues and have advised us there has been an isolated case with a Skoda model with identical symptoms so they have now advised us to change ignition switch.
We have indeed ordered replacement ignition switch but this has to come from Germany so unfortunately we do not have a delivery date as yet.
I suggest we monitor delivery schedule of the switch during this week and decide before the end of the week if you want to stay in our Golf demonstrator loan vehicle or indeed want to use your GTi since the effects of the lights coming on create no running problems?
We will be monitoring supply of the switch daily and update you of any change in position.
This does look like to most positive outcome to this needle in haystack we've all been frustrated with.
 :sick: :sick: :cry: :cry:
Build Week 11.04.16 - 2016 Mk7 Golf R, Lapiz Blue 5 door manual, 12 months R/Tax, 2 yrs free service, full tank of fuel, sure guard, and private plate transfer
2015 Mk7 Gti 5 DR, Carbon Steel Grey, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
2013 Mk7 Gti 5 DR, Pure White, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
Offline topher
  • Administrator
  • fully functioning
Re: More Problems
« Reply #14 on: 18 December 2014, 19:16 »
had a 63 reg Golf in for service today and the customer mentioned an intermittent stop/start error when turning on ignition, checked the faults and found a couple for steering angle sensor low voltage so sent him off to the dealers with the suggestion of a faulty ignition switch... wonder how many more i'll see!
Offline am1w
Re: More Problems
« Reply #15 on: 18 December 2014, 21:51 »
Wondered if this ignition switch problem is with both 'keyless' and 'key' cars?
« Last Edit: 18 December 2014, 21:54 by am1w »
Re: More Problems
« Reply #16 on: 18 December 2014, 22:45 »
@topher - are you approved VW service partner?
Just wondering as my nearest VW dealership are ..... Well, let's just say I'm having creative differences with them. :D
Offline topher
  • Administrator
  • fully functioning
Re: More Problems
« Reply #17 on: 19 December 2014, 09:03 »
block exemption allows us to service them and keep the warranty intact, we don't get involved with manufacturer warranty work though. 3rd party warranties we deal with all the time.
Offline vaughn
  • now team wagon, and team grumpy trainee
Re: More Problems
« Reply #18 on: 22 December 2014, 14:19 »
Sounds like my mk7 gtd, only had it for 3 mths and been back to the dealers 4 times with the same fault codes appearing. The wife let the dealership pick the car up on Friday and fobbed her of with some golf/Tiguan thing,
My gtd is dsg and the hire thing is manual, she has dsg due to back problems.
now waiting to hear back from cust services regarding a gtd dsg as a minimum courtesy car or they swap the car for a new one as the supposed parts won't be in till after Xmas,
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline Aifer
Re: More Problems
« Reply #19 on: 23 December 2014, 09:56 »
check my post and replies on something similar in a different blog.
hope it may help.
http://www.golfmk7.com/forums/showthread.php?p=74462
