Author Topic: crankshaft fan belt pulley..  (Read 2203 times)
Offline sparkplug
« on: 21 November 2014, 14:37 »
where can I buy one for a type 19 early 8v ?
I can only see used ones on evil bay TBH...for such an old bit ,i'm worried about the rubber being dud too
....mines wobbling about like a fat bloke at a disco FFS  :angry:
« Last Edit: 22 November 2014, 10:53 by sparkplug »
1986 GTI atlas grey
Offline Mr Blue
Re: crankshaft fan belt pulley..
« Reply #1 on: 21 November 2014, 19:01 »
Just a none power steering belt no?
Offline sparkplug
« Reply #2 on: 21 November 2014, 20:18 »
non power steering yes.. the original is a cast iron center with a rubber sandwiched between an outer cast iron section, which i guess is for anti vibration?
« Last Edit: 25 November 2014, 10:31 by sparkplug »
1986 GTI atlas grey
Offline sparkplug
« Reply #3 on: 22 November 2014, 10:53 »
...well i have taken a chance on a used one  :smiley:
 the old one sounded like the big ends knocking ,so i dropped the sump checked the mains & big ends all OK
the oil pump pick up strainer etc.
my mate who used to be an AA patrol spotted the pulley problem  :cool:
1986 GTI atlas grey
VW BUSH
« Reply #4 on: 22 November 2014, 14:49 »
Can you not use the Mk3 item? maybe off an early 2E or 1.6
Worth eyeballing one up from a scrappy then buying a new one if it works out maybe.
Offline sparkplug
« Reply #5 on: 22 November 2014, 18:33 »
cheers ,will have a look but unsure which pulleys are the same type TBH
1986 GTI atlas grey
Offline sparkplug
« Reply #6 on: 25 November 2014, 20:21 »
 the used one has arrived & put it on today , hey presto no knocking noise  :grin:
the old one had separated the center was spinning inside the outer  :shocked:
1986 GTI atlas grey
