Author Topic: Cab wipers  (Read 1610 times)
Offline bugbits
  • Aircooled airhead
Cab wipers
« on: 13 September 2005, 21:04 »
Having some bother with the wipers on my cab.  They've been sweeping really slow but yesterday gave up the ghost completely, mid sweep!!
Checked the fuses and all ok, are there any relays that need testing too, or is the problem more terminal within the motor itself??
'82 Gti Cab btw!
Many thanks
ello ma
Judderi
Re: Cab wipers
« Reply #1 on: 14 September 2005, 08:38 »
Sounds more like the motor to me. Try taking a direct live feed to the motor and see if it works.
Offline gibby
Re: Cab wipers
« Reply #2 on: 14 September 2005, 08:57 »
Maybe the relay terminals need a bit of a clean up. Have a look at this site for fuses and relays.  :smiley: --> http://dana.ucc.nau.edu/~kaw5/electrical.htm
......now officially dubless.
Offline bugbits
  • Aircooled airhead
Re: Cab wipers
« Reply #3 on: 14 September 2005, 12:15 »
Thanks for the info. What a great site that is! Very useful.
Will test the motor out. Are replacements easy to come by?
ello ma
Offline Phil303
Re: Cab wipers
« Reply #4 on: 14 September 2005, 20:15 »
Might not be the motor.
Mine stopped too, so I bought a reconditioned motor without checking everything first.
Turns out the mechanism had totally seized up on the passenger side. Even with a pair of sturdy spanners, I couldn't budge the arm at all. The motor was fine after all that.
They are easy to find in breakers yards and I think any MK1 motor will do. Should be about £10-£15 quid?
Offline bugbits
  • Aircooled airhead
Re: Cab wipers
« Reply #5 on: 15 September 2005, 21:16 »
Got it spot on - seized mecanism at the passenger side!!
A few bashes with a rubber maller and some WD40 sorted it out!
Cheers for the advice!
ello ma
