Author Topic: Tyres Shocker  (Read 11252 times)
Offline Mr Savage
Re: Tyres Shocker
« Reply #30 on: 09 December 2014, 20:12 »
The camber on my GTI is out but VW refused to fix it because they can't be bothered removing the subframe.
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
Offline corgi
Re: Tyres Shocker
« Reply #31 on: 09 December 2014, 20:56 »
AFAIK, camber Is not adjustable on the Golf... That means it was out at the factory or some damage has occurred. When you say it's out, how is it out? Is it positive or negative? Is it even both sides?
If it were me I'd be insisting...
Corgi
Offline Gnasher
  • Formerly GnasherVXR
Re: Tyres Shocker
« Reply #32 on: 12 December 2014, 18:10 »
Not sure why then - it had the tracking done regularly but was slightly lowered from standard - never any stability issues. I was pumping 280 odd BHP through the front wheels though!
The fact is the most common cause of wear on the inside edge of the front tyres of a car is toe-out, not camber... unless you do some fairly extreme driving e.g. lots of time spent cornering hard - lots of track days on a tight and twisty track.
My first Integra Type-R used to root the front tyres in about 7k miles... I had a full four corner geo done and it was there was excessive toe-out. This was reset to a small amount of toe-in and suddenly the fronts lasted over 12k miles... and the car was transformed... Even with quite a bit of camber (within the spec) on my 911, the front tyres wear evenly because it is set with a little toe-in.
I don't know what the tracking parameters of the Golf are, but they could well be 0 + or - a small amount. The thing is if they are set parallel then under load they're like to run with a bit of toe-out owing to the flex in the suspension.
For me, I'd be asking them to set the tracking to allow for a little toe-in if the spec allows.
The amount of power shouldn't make a difference to the evenness of tyre wear... just the amount  :grin: unless of course, there's so much that when you use the power it distorts the suspension...
Mind you, it was a Vauxhall and all the ones I've owned seemed to wear the inside edges.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
