Author Topic: Tyres Shocker  (Read 11253 times)
Offline am1w
Re: Tyres Shocker
« Reply #20 on: 02 December 2014, 12:25 »
Majorkhan: Conti 5s on yours? You lucky sod! I'd rather have 14k miles on those than 17k miles on the Bridgestones.
You've not done badly at all. Same again?
Lucky is not the word. You and I will probably end up with horrid Bridgestones.
Offline dirvy
Re: Tyres Shocker
« Reply #21 on: 04 December 2014, 13:46 »
Service today, 9250 on clock, new front tyres!!!
Offline DorsetDC
Re: Tyres Shocker
« Reply #22 on: 04 December 2014, 18:37 »
Just ordered 2 Conti's with 11,000 on the clock.
Golf R 7.5 Diamond Black, Discover Media Navigation, DSG, Winter Pack.
Offline Gnasher
  • Formerly GnasherVXR
Re: Tyres Shocker
« Reply #23 on: 05 December 2014, 08:39 »
Am I the only one that thinks the OP has nothing to worry about with his front tyres wearing out at 14k?
My GTI PP has less than 6k on it and I've got 2-3mm left on the fronts and I drive pretty steadily as well as running the thing in for around 1500 miles.
That said, I've gone through a Cypriot summer (40-45 degrees most days at the height of it) which might have accelerated the wear slightly.
Slight change in plans - looking for new tyres now! still less than 6k miles but on closer inspection they'll definitely not be legal soon (if not already)!
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline Damo66
Re: Tyres Shocker
« Reply #24 on: 05 December 2014, 16:39 »
7.5k and my front pierelli's are nearing the limit.
Beetle (1975)
MK2 Golf GTI 16V
MK3 Golf GTI
Corrado G60
MK3 VR6
Passat Sport PDI
MK4 Golf GTI PDI 150
MK5 GTDI 140
MK5 Golf GTI
MK6 Golf R
MK6 Golf GTD
MK6 Golf GTI Ed 35
Beetle Sport TDI
MK7 Golf GTD
Offline Mr Savage
Re: Tyres Shocker
« Reply #25 on: 08 December 2014, 21:16 »
How have you got through the tyres in 6,000 miles? I'm guessing you have the Bridgestones? Mine are still with 2.5mm after 12,000 miles....
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
Offline Gnasher
Re: Tyres Shocker
« Reply #26 on: 09 December 2014, 05:22 »
I got the Conti's - I drive fairly quickly but I'm not driving like a loon. I've had the odd 'play' but I'm not into pulling out of junctions with smoke coming off the tyres. I'm just wondering if the PP diff is making a difference. My previous car (no LSD) would wear the tyres on the inside edges due to higher slippage on the inside wheel but the diff would virtually eliminate this.
Offline corgi
Re: Tyres Shocker
« Reply #27 on: 09 December 2014, 13:54 »
More likely that the wear on the inside edge of the tyres is due to you running some toe-out, inadvertently... which is not good, for tyre life or stability under braking.
Diff should have no effect on tyre wear in normal driving and should not change the wear pattern...
Corgi
Offline Gnasher
Re: Tyres Shocker
« Reply #28 on: 09 December 2014, 14:02 »
Not sure why then - it had the tracking done regularly but was slightly lowered from standard - never any stability issues. I was pumping 280 odd BHP through the front wheels though!
Offline corgi
Re: Tyres Shocker
« Reply #29 on: 09 December 2014, 17:59 »
The fact is the most common cause of wear on the inside edge of the front tyres of a car is toe-out, not camber... unless you do some fairly extreme driving e.g. lots of time spent cornering hard - lots of track days on a tight and twisty track.
My first Integra Type-R used to root the front tyres in about 7k miles... I had a full four corner geo done and it was there was excessive toe-out. This was reset to a small amount of toe-in and suddenly the fronts lasted over 12k miles... and the car was transformed... Even with quite a bit of camber (within the spec) on my 911, the front tyres wear evenly because it is set with a little toe-in.
I don't know what the tracking parameters of the Golf are, but they could well be 0 + or - a small amount. The thing is if they are set parallel then under load they're like to run with a bit of toe-out owing to the flex in the suspension.
For me, I'd be asking them to set the tracking to allow for a little toe-in if the spec allows.
The amount of power shouldn't make a difference to the evenness of tyre wear... just the amount  :grin: unless of course, there's so much that when you use the power it distorts the suspension...
Corgi
