Author Topic: front brake pad sensor is on... should i be changing these asap?  (Read 2673 times)
Offline candywhite12
as the title suggests.  Have about 40k on the car, haven't changed pads so far.  I only drive to work about 30 miles per day.  Would it be terrible if i don't change them for another 3k since my next car service is then?
thanks
Current: GTI 8.5, Moonstone Gray, 5dr, Black Estorils 19''. pan, DCC
Wife's: mk8 TSI 1.5 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Son's: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline joe6
Not sure how much pad you have left when the warning light comes on. You really need to visually check the pads to be sure. Did the garage give you a warning at the last service (if it is on an annual regime)? Normally keen to sell brake pads so would have thought they would have spotted worn pads or listed wear on the service check sheet.
Offline AndyWard
Warning Light always come on way to early for me.
A good visual check will provide the answer you need, then a quick squirt with a vag com removes that pesky light.
Just remember to check occasionally :)
10 Plate, Silver DSG,  APR Stage 2, APR TBE, Carbonio Intake 1 + 2, Bilstien B8 + VWR Springs, Eibach Front & Rear Roll Bars Powerflex Bushings, TyrolSport Subframe Deadset Collars, Whiteline Endlinks Front & Rear, Neuspeed TOP and Intercooler Pipe, R8 Coilpacks,
good idea although not much of a mechanic myself so wouldn't know how to visually check them cry: any indication would help
Offline joe6
Just checked the repair manual. The warning comes on with approx 4mm of pad left and the minimum allowed pad thickness is 2mm so should be OK until the service. Still should to do the visual check though. Really need to take the wheel off to see properly or put the vehicle on a hoist. Tried and failed to put a diagram on here!!
right mate, appreciate your help.  i'll b taking it to the garage soon as i don't want to be risking anything
