Author Topic: car wont run  (Read 12041 times)
Offline 1981t25gti
car wont run
« on: 15 November 2014, 14:48 »
hello , can anyone help , i had my ecu chipped and had problems with it so i have bought a replacement ecu complete with immo and chip , plugged it all in and it fires up but wont run , i can hear the fuel pump priming , and there is plenty of fuel in , any ideas ?
cheers dave
Offline topher
  • Administrator
  • fully functioning
Re: car wont run
« Reply #1 on: 15 November 2014, 17:53 »
what car?
Offline 1981t25gti
Re: car wont run
« Reply #2 on: 15 November 2014, 23:56 »
hello , sorry its a mk3 gti 8v AGG engine code
cheers dave
Offline topher
  • Administrator
  • fully functioning
Re: car wont run
« Reply #3 on: 16 November 2014, 12:19 »
unless you've swapped the immo box and key to match the ecu then you'll need to find someone with vagcom to pair up the replacement ecu to the immo
Offline 1981t25gti
Re: car wont run
« Reply #4 on: 16 November 2014, 13:45 »
yes i have swapped the whole lot including the immobilizer and transponder that came with the ecu
Offline Diamond Hell
  • Opinions я Us
Re: car wont run
« Reply #5 on: 16 November 2014, 20:36 »
Did you see the car they were from running and then take the box, key, ring and ECU out of the car?
Sure they're all from the same car?
Offline 1981t25gti
Re: car wont run
« Reply #6 on: 17 November 2014, 22:36 »
hello , no i didnt see it running , just bought it from a company on ebay , i have a bypass for the immobilizer so  i might try and see if that works,
Offline 1981t25gti
Re: car wont run
« Reply #7 on: 17 November 2014, 22:38 »
it fires up and runs for a split second before stalling , would the immobilizer do this ?
Offline Bellend
Re: car wont run
« Reply #8 on: 18 November 2014, 11:18 »
Yes.
Where all my moneys went.
