Golf mk4
Wazzzer
tyre hight diffrence between 205/55/16 and 215/45/17
Topic: tyre hight diffrence between 205/55/16 and 215/45/17 (Read 1622 times)
viperjsy
12 November 2014, 14:32 »
hi are thay the same hight or is the 17 an inch smaller
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: tyre hight diffrence between 205/55/16 and 215/45/17
12 November 2014, 16:23 »
the rotation circumference on the 215/45/17 is 1% smaller, i.e. you speedo will read 1% too much
you will also loose 3mm ground clearance.... so no issue
viperjsy
14 November 2014, 22:00 »
thank you
Golf mk4
Wazzzer
