Author Topic: Drive shaft  (Read 3027 times)
Offline Tezmax
Drive shaft
« on: 08 November 2014, 20:04 »
Off side drive shaft required, will any Golf mk4 drive shaft fit (1.6 2.0gti Diesel) straight onto my 18t.
Or before I replace it, is there a repair kit for either end?
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline SI74
Re: Drive shaft
« Reply #1 on: 09 November 2014, 23:26 »
What's wrong with it?
You can buy a need boot and that.
Offline Tezmax
Re: Drive shaft
« Reply #2 on: 10 November 2014, 17:11 »
Sounds like I have a farm of pigs squealing under my off side wing.
Replaced disc's and pads, suspension arm with bushes and top mount rubber bush.
Nothing left to change other than the CV joints or whole drive shaft if easier.
Passed MOT on Sat but they dont run it on rolling road when testing :smiley:
« Last Edit: 10 November 2014, 17:17 by Tezmax »
Offline MoMartin
Re: Drive shaft
« Reply #3 on: 10 November 2014, 17:37 »
It's not the arb rubbing on the driveshaft is it?
Offline gm8
Re: Drive shaft
« Reply #4 on: 10 November 2014, 17:56 »
wheel bearing ? did you renew the pinch bolt ?
Offline Tezmax
Re: Drive shaft
« Reply #5 on: 10 November 2014, 18:17 »
Got no visible wear marks or shiney areas on the drive shaft.
Not touched the bearing, is the pinch bolt the castle looking bolt holding the hub on?
Dont want to remove anything until i'm replacing the faulty bit :wink:
Offline gm8
Re: Drive shaft
« Reply #6 on: 11 November 2014, 09:34 »
if you took the whole strut out to replace the top mount then you should really replace the pinch bolt, its a one use. My knocking was cured when I replaced my top mount and fitted new bolt. Dont need to touch the wheel bearing for it to give up. Jack car and rock wheel 12/6 position ans 3/9 position. If movement in both then bearing could be at fault .
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Drive shaft
« Reply #7 on: 19 November 2014, 12:31 »
J&R, search for them on ebay. They do DS for £40ish quid delivered and they garuntee them for 12 months.
Offline Tezmax
Re: Drive shaft
« Reply #8 on: 19 November 2014, 17:43 »
Thats pretty cheap.
Noise stopped and has not come back since Friday, the noise has gone from waking the whole street up at 7am to complete silence :undecided:
Work that one out :huh:
Offline gm8
Re: Drive shaft
« Reply #9 on: 21 November 2014, 18:23 »
someone had bacon ?
