Golf mk2
TD starter in GTI - bearing too small??!!
Topic: TD starter in GTI - bearing too small??!! (Read 1564 times)
e11ie
Here all the time
05 November 2014, 22:00 »
Hey
Car is mk2 8v with 2L conversion but running an 020 box.
Brought a new starter and after a little research decided to get a mk2 TD starter motor as they are "beefier"
Brought this model after reading a few good reviews about ATP
http://www.ebay.co.uk/itm/371145281521?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
However tried to fit it today and it wouldn't fit into the gearbox. On comparison the input shaft part is larger than the one I removed.
I removed the bush too and there was definitely no way it would fit around the new starter.
Wondered if there was a different size bush for diesel starters but nothing, in fact pretty much every watercooled vw before 1995 uses the same bush!
Vw spec - 11mm ID 13.6mm OD
I ideally need - 12mm ID 13.6mm OD
I found this (14mm OD) and considered making a thin cut down one side so that when it was inserted it would squeeze in on itself and fill the gearbox hole?
http://www.ebay.co.uk/itm/02181-Febi-Bilstein-Clutch-Starter-Bush-Skoda-FELICIA-/161454647179?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item259772678b
Am I missing something or have I been sent / ordered the wrong starter?
Ellie
Golf mk2
