Author Topic: How to lock your window up if your regulator breaks  (Read 2498 times)
Offline philstar
  • ...life is all about creating memories...
« on: 05 November 2014, 08:18 »
Hi guys, apologies if this is in one of the manuals already!
If your window regulator fails and you need to lock your window in the upright position temporarily, you can do this very easily by screwing a couple of 50mm bolts into the window clamp through two holes at the top of the door.
https://drive.google.com/file/d/0B59jukMYhgqNQWl4V1Fybl9FNTg/view?usp=sharing
https://drive.google.com/file/d/0B59jukMYhgqNc2c4b0tFQm0xaHM/view?usp=sharing
1988 Atlas Grey VW Golf Mk2 16V GTi [F748 FGT]
Rebuilt: fuel pump housing | suspension | gear linkage | aluminium radiator
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: How to lock your window up if your regulator breaks
« Reply #1 on: 05 November 2014, 11:10 »
This happened to me yesterday in the corrado and just used a couple of bits of 2 x 4. Would be interesting to see if it has similar holes to the mk2. Will check later.
Offline philstar
« Reply #2 on: 10 November 2014, 09:56 »
I have converted my drivers' door to manual while I repair the electric motor, but does anybody know where I can get the screw to hold the window winder handle on? Or know what size I need?
VW BUSH
« Reply #3 on: 10 November 2014, 17:28 »
Look on Vagcat/Etka, will give you a dia and length
Lol, I have had two lengths of wood before one for shut and one for crusing :grin:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #4 on: 10 November 2014, 17:44 »
This happened to me when my regulator wire snapped. I just used a stick to keep it up.
 :grin:
