Author Topic: Ebay wishbones  (Read 3934 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Ebay wishbones
« on: 28 October 2014, 18:25 »
Hi guys,
Anyone had any experience with buying the £60ish a pair of wishbones from Egay?
I am keen to replace all of my bushes on my wishbones, and maybe even my wishbones and as time is precious I'm planing on having a pair with new bushes already in, so I can just switch 'em right out?
Any suggestions,
Cheers.
Offline scarr89
Re: Ebay wishbones
« Reply #1 on: 28 October 2014, 18:26 »
Also, are the wishbones compatiable within the models, ie 1.8T same as the 1.9TDI's?
Offline SI74
Re: Ebay wishbones
« Reply #2 on: 28 October 2014, 19:47 »
I got a second hand set, blasted them and fired on some paint then fitted the TT/R32 solid rear bush and new standard bush.
There's only one standard wishbone the R32 has the different one.
Offline Rhyso
Re: Ebay wishbones
« Reply #3 on: 28 October 2014, 19:50 »
Fitted a set to mine when I had it
What I did do though was fit them with OEM balljoints and TT bushes
Offline boneybradley
  • Back in a Mk3...
Re: Ebay wishbones
« Reply #4 on: 28 October 2014, 20:10 »
Why go for unknown quality spurious wishbones, a good branded wishbone by firstline is only £26 each (without ball joint) or febi is £36 (without ball joint)
b.t.w i stock r32/tt spec rear arm bushes by febi £26 pair (or i can do genuine)
Offline scarr89
Re: Ebay wishbones
« Reply #5 on: 28 October 2014, 21:15 »
This is what I think I am going to do...
Second pair I guess? I'd also like to paint them, keep them looking clean  :smiley:
Boney - I'll PM you, see what we can come up with. Your sounds better than the egay options...
Offline SI74
Re: Ebay wishbones
« Reply #6 on: 28 October 2014, 21:33 »
I think I have two sets of genuine ones in the garage one with the TT bush in it. No longer needed as I've the R set up now.
Offline mcgee9t2
Re: Ebay wishbones
« Reply #8 on: 29 October 2014, 13:08 »
friend of mine got his from ebay, the welds werent the best and he had to grind a little bit off some of them as the welds stuck out so much you couldnt get the pivot bolt through.
hope yours are a bit better
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Ebay wishbones
« Reply #9 on: 29 October 2014, 20:13 »
TT wishbones FTW
