hope someone can point me in the right direction.
Yesterday me and the kids went out for a drive in the 20v drove lovely for 20/30 miles stopped off for a bit.
then on the way home along the motor way the car started to judder under acceleration then started firing on 3 cylinders, but kept going back to firing on 4 just really temperamental.
Managed to limp it home, stuck it in the garage until this morning i checked all connections,fuel pump still priming but will only fire on 3 cylinders today.
fuel starvation maybe (blocked injector/filter) didnt change filter in service
today i swapped the coil packs over and im getting the car to tick over but as soon as you start to rev it coughs and sputters
i disconnected in turn the coil packs and the engine noted changed to all 4 and wanted to stall
also disconnected in turn the injectors and same problem.
could this be either a fuel issue. ie change the filter or vacuum maybe
all comments welcome
thanks
