Author Topic: Grinding sound  (Read 2356 times)
Offline golf turbo47
  • PURE BOOST!!!
Grinding sound
« on: 21 October 2014, 17:19 »
Hello all I got a 2001 1.8t Gti & im at a total loss with a problem. I'm sometimes getting a grinding noise coming from the rear when braking to a stop & when I pull away. I've checked rear discs & pads. And also checked front discs & pads and all seems fine. Any ideas what it could possibly be would be a great help?
Cheers.
Silver 2001 1.8T AUM. Revo remap. hybrid K03s.  jetex filter. forge 007p. decat pipe. custom exhaust. anni front valence. rear 4mo valence. anthracite montreal 2 alloys. To be continued....... TIP, H&R suspension,Black 19" RS4 alloys, Carbon fibre wrap roof. anni rear valence, Almost there.....
Offline barrym381
Re: Grinding sound
« Reply #1 on: 21 October 2014, 19:08 »
rear caliper sticking they are bad for it  :smiley:
Offline MoMartin
Re: Grinding sound
« Reply #2 on: 21 October 2014, 19:13 »
stone stuck in the brake, Warped disk, or a Noisy wheel bearing is my guess
  • PURE BOOST!!!
Re: Grinding sound
« Reply #3 on: 23 October 2014, 06:56 »
Cheers guys for the reply.
Does anyone know where the best place to get rear brake calipers from & how much?
Offline WadGTI
  • Golf GTI'er
Re: Grinding sound
« Reply #4 on: 23 October 2014, 12:32 »
Have you not already got a set on the back? :grin:
Best to strip it down, clean it and rebuild it before bying new ones..my view anyway.
Offline Bellend
Re: Grinding sound
« Reply #5 on: 23 October 2014, 12:48 »
This.
The tiniest amount of corrosion seizes em up and a rubber grease and clean up and most of the time good as gold.
Where all my moneys went.
Offline mcgee9t2
Re: Grinding sound
« Reply #6 on: 23 October 2014, 13:02 »
not sure how much they cost etc. cause i get stuff at trade price, however, when i replaced one a few years ago it was about 30-40 quid iirc so proberbly looking at 60+
i do think vw do a service kit type thing with all new seals etc in so could try stripping it down and re building with new parts.
could also try jacking it up and using a pair of mole grips or simelar to move the hand break lever while spraying with some wd40 or some cleaning agent to try and remove any muck/rust etc. worked as a temp repair on mine for a few months prior to replacing the caliper
Offline Tezmax
Re: Grinding sound
« Reply #7 on: 23 October 2014, 17:00 »
Your gona need a wind back tool either way :whistle:
 £8.00 Amazon :smiley:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
