Author Topic: anti roll bars and sway bars  (Read 2011 times)
Offline gtimadmike
« on: 20 October 2014, 21:53 »
im thinking of installing some bars to stabilize. whats peoples opinions on having a full set of front/rear strut bars and sway bars or would t be better to just go for one or the other?
stage one remap,jom coilovers, pipercross cone filter, vr6 clutch, 20mm spacers all round, silicone tip, ko3. for now ;)
Offline shaft69
Re: anti roll bars and sway bars
« Reply #1 on: 20 October 2014, 22:37 »
If read white line's review found best handling by fitting just rear, I run h&r front/rear spot on but need good suspension too I run h&r  coilovers too with under car front strut.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline gtimadmike
« Reply #2 on: 20 October 2014, 22:46 »
cheers pal yeah just seen youtube vid of whitelines may just give that a try first n see how she goes, can always add more ;) ive only just bought the car and its on jom's but thinking of changing them too. had an issue the other day where front  left was out by 3mm and back right out by three. i sorted the front but the back right wont go anymore anfd they are both sat at the bottom so no more adjustment room......shocks gone maybe?
Offline Scott D
« Reply #3 on: 24 October 2014, 17:17 »
I would try fitting a rear first see how get on with that. Make a world of difference to the handling with only a rear on although depending on size will become a bit tail happy which is good long as aware :)
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline gtimadmike
« Reply #4 on: 26 October 2014, 20:19 »
Sound will give that a whirl I'm sure I will find what I find comfortable and fun to drive
