Author Topic: Recirc valve popped off - anyone else had this?  (Read 3483 times)
Offline MoMartin
« on: 20 October 2014, 19:47 »
I have the forge 007p, and today I took my car out for a drive and noticed that it was a lot louder than normal, after quick inspection I noticed it had completely blown itself out of the tip, I'm sure that the clip holding it in was pretty tight, but I can't be 100 percent sure. I'm running a k03 on an aggressive stage 2 r tech map so it might be over boosting also I'm running the green spring on the 007p (seemed the most responsive - but it was also  very hot when I checked so I might need to change it to a stronger one?)
Thanks, Mo
Offline james2
  • No scammers please.
Re: Recirc valve popped off - anyone else had this?
« Reply #1 on: 20 October 2014, 20:03 »
make sure the clip is tight.  :laugh: it shouldnt pop off.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline MoMartin
« Reply #2 on: 20 October 2014, 20:37 »
Ha that's what I was thinking... I mean how much air is recirculated to the point where it actually blows out haha
Offline Dalo Harkin
« Reply #3 on: 21 October 2014, 12:53 »
How much boost you running?
Offline MoMartin
« Reply #4 on: 21 October 2014, 14:02 »
No idea really, whatever the k03 could handle I think, I'm on 190 to 198 bhp if that helps you tell how much I might be on
Offline Dalo Harkin
« Reply #5 on: 22 October 2014, 13:07 »
probably around 1 BAR, is it a K03 or a K03s because a stage 2 I would think is a K03s but around the 190-200BHP is a stage 1 K03
Offline MoMartin
« Reply #6 on: 22 October 2014, 21:19 »
It's a k03  :sad:
I remapped it before I knew much about these cars, only to find it had the smaller turbo. To add to that, all the mods on it were done before I bought the car which is annoying  because they spent all the money in places that don't harness much power
And it's stage 2 because it's got a decat, fmic, pipercross filter and the forge 007p.
Offline Dalo Harkin
« Reply #7 on: 24 October 2014, 13:11 »
ah ok, stage 2 refers to the map on it.
With all those mods and the FMIC, just get a K03s on it and get it mapped  :evil:
Offline MoMartin
« Reply #8 on: 24 October 2014, 17:02 »
I wish i could haha, its just the money required to be honest, i think if i do upgrade to a k03s ill get the oversized tip, maf  and change the injectors too, because they max out at about 220 (i think)
Offline Scott D
« Reply #9 on: 24 October 2014, 17:05 »
240-250 with those mods and a turbo with strong actuator :)
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
