Author Topic: I GIVE UP  (Read 1853 times)
Offline james2
  • No scammers please.
I GIVE UP
« on: 19 October 2014, 21:25 »
 :cry: Rocker cover gasket ,injectors, sump and coolant leak.  :embarrassed: other things aswell wrong.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Dalo Harkin
Re: I GIVE UP
« Reply #1 on: 20 October 2014, 08:25 »
that's all not too bad, will take you anything from 2 hours - half a day depending on what else is up
Offline james2
Re: I GIVE UP
« Reply #2 on: 20 October 2014, 20:01 »
The water leak is on a metal pipe across the front of the engine, it looks a nightmare to get out. Its only a pin hole so i put half of a rubber pipe on it and a jubilee clip, the leak has stopped for now. Iv ordered a rocker cover gasket. Ill leave the injectors and the sump as it has small cracks in it and needs a new one.  :embarrassed:
Offline Dalo Harkin
Re: I GIVE UP
« Reply #3 on: 21 October 2014, 12:55 »
I've actually got a spare sump, it just needs the main drain hole tapping for a bigger bolt, was cross threaded is all
