Author Topic: Indicator not working  (Read 2958 times)
Offline lewy20004
« on: 17 October 2014, 20:08 »
good evening
Hope someone able to advice me on my indicator issue
I'm thinking (hoping it maybe relay)
Anyway all side repeater's work when you sap the alarm on or off.
Click hazards on and just the left side works (green light on dash etc)
But nothing from the right no fast flash no lights at all (not even dash light)
When driving, left works fine yet again lights on dash etc but nothing on the right when I indicate right.
I thought it may have been the stalk but surly it would work on hazards
The relay 21 clicks and once removed nothing works. (Could this be faulty )
Or is this a complete wiring issue
Many thanks
Offline theclash
Re: Indicator not working
« Reply #1 on: 17 October 2014, 22:20 »
Check the wiring in the engine bay there's a spade connector male and female that link both sides some where below expansion tank or around that area I had same problem last year and it was that connector rusted up , follow the wiring back from the wing and you should find it.......worth a try
Offline lewy20004
« Reply #2 on: 18 October 2014, 11:08 »
I have chased the wiring and all seem fine.
Correct me if im wrong but if it was the wiring then the indicators wouldn't work when alarm activated.
I have a relay on order. But could it be the stalk?
Offline Craigwilson
« Reply #3 on: 18 October 2014, 12:47 »
have you checked the wiring Behind the dash? the alarm operates the indicators independently but if theyve been spliced into the loom at some point something could have became disconnected, I think it's wires coming from the stalk which are left black/white and right black/green
Offline Sgt_Lemon
  • 8v owners club
« Reply #4 on: 18 October 2014, 13:51 »
Maybe where the alarm was spliced into the hazards has broken. I would check under the dash
Offline lewy20004
« Reply #5 on: 18 October 2014, 14:13 »
Nice one guys.
Took the steering column off and lower dash unhooked connection then re attached and BOOM!! Itsworking
Thanks forthe help
