Author Topic: Pulling to right when throttle pressed hard  (Read 2062 times)
Offline bigberty101
« on: 16 October 2014, 12:59 »
Afternoon guys
had a good look around online fist and cannot find anything about this. recently brought a mk4 golf gttdi pd 150, when driving along at a steady pace and driving normal, the car tracks straight and drives fine. When you bury your foot and have a bit of fun, anything over 30ish mph, the car pulls to the right slightly. easiest way to describe this is it feels like the front right is lifting up, steering wheel turns to the right slightly and becomes very sensitive and unstable at 60-70mph ish. its ok to drive but cannot really find anything wrong.
its recently had new wishbones and ball joints, tracking has been done recently, tyres are at 32 psi all round, top mounts don't seems too bad, ive got new tie rods, track rods, top mounts and bearings, and new wishbones / ball joints to fit (they look like cheap crap) ive fitted new pads, discs and hubs to rear last week. ( rear wheels arnt binding.
I spotted today that is looks like the front right caliper is binding slightly, disc has a brown / blue tinge to it and none other have it.
What do you guys recon? any suggestions?
thanks in advance
Offline james2
  • No scammers please.
Re: Pulling to right when throttle pressed hard
« Reply #1 on: 16 October 2014, 14:21 »
Afternoon guys
thanks in advance
I would check the brake out ,sounds like its binding.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline bigberty101
« Reply #2 on: 16 October 2014, 14:26 »
yea I was going to when I get home from work, just starting to annoy me now
Offline james2
« Reply #3 on: 16 October 2014, 14:52 »
When you get home jack the wheel up and try turning it around by hand. I bet it will not move.
« Reply #4 on: 17 October 2014, 21:04 »
Sounds like your caliper is sticking.
