Author Topic: 2.0 8v not starting  (Read 8857 times)
Offline ARB1991
Re: 2.0 8v not starting
« Reply #10 on: 20 October 2014, 16:37 »
ok so its running now, thanks for all the input guys.
she's now topped up on oil, ran some redex through the tank, sprayed a little easy start into the TB, and WD40 on electrical connections and dizzy, she fired up, ran a little rough at first with a bad misfire under full throttle, but after she warmed up properly and ever since she's been fine.
I'm guessing that I'm gonna need to buy some new parts, start with a new dizzy?
I'd rather push my Golf than drive a FORD
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 20 October 2014, 20:56 »
new dizzy or dizzy cap?
b.t.w let me know what you need and I will try and sort a good deal (sales@oemandmore.co.uk)
Offline Jasikasisback
« Reply #12 on: 22 October 2014, 14:06 »
I have the same engine in my passat b4....i.changed everything mentioned in this post by others and no go. It took my very skilled mechanically inclined friend wh removed the distributor as it was not aligned properly even though getting spark to plugs....so check.the distributor timing and timing of cambelt....my friend said it was a mystery as to how.the timing was off...who knows? these old cars surprise you....
After all that work the car still cut out at 70mph for a few.seconds on the motorway....scary stuff...dropped revs and then sprang back to life...did this for many months and then stopped....after that it wouldn't start again ....that disappeared after changing the engine oil....go figure...
Offline jimmydub
« Reply #13 on: 22 January 2016, 11:00 »
Hi all,
I know this is an old thread but just wondering If I remove throttle body from an AGG will it need vag-com reset?
Offline itavaltalainen
« Reply #14 on: 22 January 2016, 18:56 »
I'd recommend to run the TB alignment procedure in VCDS for all 2.0 engines in the mk3 with exception of engine code 2E.
Offline jimmydub
« Reply #15 on: 22 January 2016, 20:44 »
Is it essential though? I don't have access to VCDS and could do without the expense right now. Also, must one depressurize the fuel system before removing TB?
« Last Edit: 23 January 2016, 09:29 by jimmydub »
« Reply #16 on: 23 January 2016, 11:40 »
AGG has a Simos control unit.... it does not teach itself. TBA with tester or VCDS needs to be done so it runs smooth.
Offline jimmydub
« Reply #17 on: 23 January 2016, 12:18 »
TBA with tester
TBA?
Ive searched threads for people with diagnostics and the guys near me havent been here for over a year.
how about cleaning in situ then? with carb cleaner i.e. ecotek, through air intake.
« Reply #18 on: 23 January 2016, 15:49 »
Throttle body alignment.
Have a look on this map....
http://goo.gl/maps/0Shx
Maybe someone on there is close to you.
I am in London on Tuesday during day time.
Offline jimmydub
« Reply #19 on: 23 January 2016, 16:20 »
of course, sorry bit of a blonde moment there  :embarrassed:
very helpful, thanks. But no one near me unfortunately and cant risk driving her too far obviously.
I'm not gonna lie i think i'm going to risk it. At least I'll know its clean and can rule out the TB being the problem. I can always Vagcom it later down the line if need be.
« Last Edit: 23 January 2016, 17:06 by jimmydub »
