Author Topic: injectors  (Read 2337 times)
Offline gtimadmike
injectors
« on: 14 October 2014, 21:13 »
i have a standard gti an wondering what type of injectors i could use. also would i need to upgrade turbo at the same time etc
stage one remap,jom coilovers, pipercross cone filter, vr6 clutch, 20mm spacers all round, silicone tip, ko3. for now ;)
Offline mcgee9t2
Re: injectors
« Reply #1 on: 15 October 2014, 12:31 »
if your wanting to upgrate injectors a common upgrade is the audi tt 225 injectors with a vr6 maf.
no you will not need to upgrade turbo at the same time.
also bear in mind what mods have been done/ are going to be done.
standard injectors run out of puff about 220bhp so if you only have a k03 not a k03s then you might aswell leave the standard injectors as you will not see 220bhp...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: injectors
« Reply #2 on: 15 October 2014, 18:06 »
AGU can upgrade to Calibra turbo yellows or Saab reds with a VR6 MAF
All others can upgrade to the TT injectors with the MAF from the same car. You will only need injectors/MAF if you want 230bhp+ and you will need all the other supporting mods to go with it
Also bear in mind injectors aren't something you can just fit and drive away, you'll need a custom map too
Offline gtimadmike
Re: injectors
« Reply #3 on: 15 October 2014, 18:57 »
cheers for the info guys much appreciated. can get quite confusing all this modding when your only just starting lol
Offline Dalo Harkin
Re: injectors
« Reply #4 on: 16 October 2014, 12:32 »
You need to do quite a few mods before you get to the point of needing different injectors and a bigger MAF
Offline tonysgti
Re: injectors
« Reply #5 on: 16 October 2014, 18:38 »
I have a set of yellow calibra injectors if interested, £50
Offline gtimadmike
Re: injectors
« Reply #6 on: 16 October 2014, 21:53 »
i thought so mate thanks
