Author Topic: Limp mode switch  (Read 1512 times)
Offline Tezmax
Limp mode switch
« on: 09 October 2014, 16:39 »
As silly as it sounds I have been travelling around in limp mode for about 6 weeks and enjoying 36+mpg on short distance journeys.
Limp mode problem now resolved but same journeys are now hitting 27-28mpg driving nice and steady.
The above mpg is about right for 6-8 mile short trips but losing up to 10mpg against limp mode figures is quite a large amount.
Am i making any sence here as this will give obvious gains and also removes the the itchy right foot scenario :smiley:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Limp mode switch
« Reply #1 on: 09 October 2014, 19:30 »
You can limit the boost to standard actuator pressure by adding a switch to the N75 feed
Offline Scott D
« Reply #2 on: 09 October 2014, 19:35 »
fit a boost controller inline with the N75 to cap the boost although using your right foot sensibly is easier  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
