Author Topic: Handbrake light stays on  (Read 3206 times)
Offline POBGTI
« on: 08 October 2014, 17:29 »
I understand this is a common problem but since we have had our golf the warning light for the handbrake is always on even when the handbrake is off.
Have replaced the switch, just replaced the sensor for brake fluid and still stays on!
Will check the brake fluid levels in a bit, but does anyone else know what the problem could be?
I've read it could be an ABS problem, but how would I know if it is the ABS?
It has it's MOT Friday and will probably fail on this problem so really need it sorted!
Thanks, Ambz :)
Offline itavaltalainen
Re: Handbrake light stays on
« Reply #1 on: 08 October 2014, 18:00 »
any fault codes?
wiring to the brake fluid reservoir sender ok? what happens if you bridge the contacts in the plug that goes on the sensor.
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 08 October 2014, 18:59 »
Most likley the fluid is low.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline POBGTI
« Reply #3 on: 08 October 2014, 19:08 »
Fluid is full so isn't that, yeah I thought about checking the wiring etc so that's next!
Offline Foreveryoungaus16v
« Reply #4 on: 08 October 2014, 19:22 »
Brake fluid,  brake fluid floater faulty, handbrake switch faulty or a sensor is faulty.
163 BHP (TSR POWER RUN)
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 08 October 2014, 19:49 »
Have the codes read,when mine stayed on the fault was in the abs module itself so I sent it for repair
Offline POBGTI
« Reply #6 on: 08 October 2014, 20:42 »
The car has had its pads changed so will also check the pad sensors see if they have been tampered with.
Thanks for every bodies help :)
Offline madmanmart
« Reply #7 on: 08 October 2014, 22:43 »
ABS brake bias failure, get it scanned.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
