Author Topic: Steaming Up  (Read 10842 times)
Offline ChrisUK01
Steaming Up
« on: 06 October 2014, 19:39 »
Hi,
I picked up my GTI new on Friday, now it has started to rain the car steams up on some of the windows.
Has anyone had this, did VW not configure the car correctly when making it road worthy?
Chris
Offline monkeyhanger
Re: Steaming Up
« Reply #1 on: 06 October 2014, 20:36 »
Yes, they do this. My last 7 new VWs have done this. You need to have the blower on the windscreen setting. If this isn't enough to stop misting up then you need to put the aircon on too (dry air blowing at the screen).
Offline matty james
Re: Steaming Up
« Reply #2 on: 06 October 2014, 21:40 »
take it back and cancel your hp agreement  :grin:
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline ChrisUK01
Re: Steaming Up
« Reply #3 on: 06 October 2014, 22:21 »
Thanks I have the aircon on the drivers side window and the one behind on the same side start to mist up.
Ha Ha don't tempt me my A5 never steamed up like this. :smiley:
« Last Edit: 06 October 2014, 22:28 by ChrisUK01 »
Offline corgi
Re: Steaming Up
« Reply #4 on: 07 October 2014, 15:42 »
it is more than likely a little residual dampness from when they prepared the car. it has, here at least, gone cold and damp in the last few days, which won't help.
As stated, leave the air conditioning on all the time and add a little heat to it if you can bare it...
If it carries on for more than a few weeks in conditions where you would expect condensation then I would start to investigate other causes...
Corgi
Offline Pixelmix
Re: Steaming Up
« Reply #5 on: 07 October 2014, 17:13 »
Our first drive home from the dealer was in the rain. Took a while to get the windscreen completely clear that day, even with the air con on. It has been much better since - must just be dampness in the system from new.
I tend to run the aircon on most of the time to keep the windows clear. Only turn it off on dry days where the temperature is right anyway.
Offline fredgroves
Re: Steaming Up
« Reply #6 on: 07 October 2014, 17:16 »
Mine fogs up quite badly too, even going along with the aircon on heat.... you have to clear it by pushing the direct at screen button.
Some car designs just seem like that, Mk7 included. :(
Offline AlanH
Re: Steaming Up
« Reply #7 on: 07 October 2014, 18:21 »
Warm, moist air + cold windscreen = condensation. It's a trait of the Golf going back several generations.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline mcmaddy
Re: Steaming Up
« Reply #8 on: 07 October 2014, 18:28 »
It's not just the golf! Leave your climate control on 22 on auto and you shouldn't have many problems with fogging up.
Offline p3asa
Re: Steaming Up
« Reply #9 on: 07 October 2014, 19:51 »
I've found if I use air con its a vicious circle. I'm guaranteed the next time I get in the car the windows will be steamed up again.
However if I just use the blower to clear the windows, the next time I get in the car they won't have automatically steamed up.
So I never use the air con and the only time I have steamed up windows is if I get in the car wet.
