Author Topic: engine wont fire after remap mk3 gti AGG  (Read 2314 times)
Offline 1981t25gti
« on: 01 October 2014, 13:26 »
hello
i recently had a performance chip fitted to my ecu on my mk3 8v gti AGG , when i plugged it all back together i noticed that when i turned the ignition key the fuel pump didnt prime , and it didnt start , i took it all out and fitted the old chip but it was just the same , i had it back to the tuners for checking and they said its ok , it must be the loom or the ecu plug , i tested the voltage at the coil of the fuel pump relay and it was as low as 2v which wont pull it in , so i put 12v onto the out going side to get the fuel pump running but it still wont fire , any clues ?
cheers dave
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
Re: engine wont fire after remap mk3 gti AGG
« Reply #1 on: 01 October 2014, 18:49 »
Did they not re solder the metal box cage in.
You need to your re teach your immobiliser with a chip change
Or they have just ruined your ecu who changed the chip.
New toy1990 Scirocco I feel a 16v conversion coming on.
« Reply #2 on: 01 October 2014, 20:58 »
Sounds like they have blown your ecu
Offline 1981t25gti
« Reply #3 on: 01 October 2014, 21:44 »
thanks for the replies , i had a socket soldered in so that i can change the chip if i want to in the future , how do i go about getting the immobilizer to reset ?
cheers dave
Offline itavaltalainen
« Reply #4 on: 01 October 2014, 22:13 »
you need vcds and mate ecu and immo unit again
