Author Topic: Mk 2 Gearbox Problem  (Read 2584 times)
Offline AutoCareUK
« on: 01 October 2014, 13:23 »
Hi all
I've just joined this forum and it looks great with some helpful people. Which is just what I need!
I recently bought a 1989 Mk2 Golf GTI 8v after wanting one for years. My plan is to try and do most of the work on it myself and learn more about the Golf as go (i'm not a mechanic!).
The problem I have at the minute is with the gearbox. The car has a brand new clutch, clutch cable and pedal box but when you change gear it makes a loud metal on metal clunk. I'm hoping someone with good knowledge is going to tell me that there is something common and not too horrific that I should look for. As you can imagine what I'm hoping I dont hear is "Your gearbox is f**ked."   :sick:
Thanks in advance for any advice.
Offline Waspy
Re: Mk 2 Gearbox Problem
« Reply #1 on: 01 October 2014, 14:19 »
Hard to tell from your description. But here are a few points to note, depending on how serious this clunk is:
- Are you used to a modern gearbox? A 25 year old box will feel VERY mechanical by comparison.
- Does it happen on every gear? A crunch into second gear is very common.
- Bushes could be shot.
Offline sparkplug
« Reply #2 on: 01 October 2014, 19:35 »
i would look at the rod linkages & bushes ,from the gear lever to the box  there are kits to replace them
1986 GTI atlas grey
VW BUSH
« Reply #3 on: 01 October 2014, 19:44 »
Do this first as its easy.
When your stroking the correct length and getting no slop left and right you know that the error in the box if crunching persists. .....
Offline AutoCareUK
« Reply #4 on: 01 October 2014, 21:20 »
Thanks for the replies it's much appreciated.
It does clunk into every gear but second is the worst. I'll take the advice and check out the bushes and rod linkages.
Thanks again, looks like this forum will be a good help in the coming months!!!
VW BUSH
« Reply #5 on: 01 October 2014, 23:06 »
2nd is a sign the sync mechanism is on its way, quite common.
Does reverse jump out as well?
Changing the oil in the box can help, do this with the link kit as its only another 30 mins and £10 of oil.
Offline Sgt_Lemon
  • 8v owners club
« Reply #6 on: 01 October 2014, 23:07 »
You could try changing the gearbox oil also. Will either help or highlight if your box is f**ked so you know to start looking for a replacement.
Edit: VW bush went and said the same thing whilst I was typing aha
Offline AutoCareUK
« Reply #7 on: 07 October 2014, 12:28 »
Thanks lads.
I doesn't jump out of reverse, yet! I'll do the gearbox oil this weekend. Looks like i'm going to be kept busy!!!!  :grin:
Offline Sgt_Lemon
  • 8v owners club
« Reply #8 on: 07 October 2014, 22:05 »
When doing the plug make sure you undo the fill plug first. If you get the drain plug off and then you can't get the fill plug off it complicates things.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #9 on: 09 October 2014, 14:45 »
Lots of Mk2 gear box info here:
http://brokevw.com/
