Author Topic: MBC Install - somthing doesnt look right  (Read 4245 times)
Offline TETSUOXGEZ
  • "If in doubt, flat out"
« on: 30 September 2014, 01:14 »
Guys i need some advice, this is the digram i have come up with for installing the manula Bosst Controller,
buti cant cant figure out why the T Peace is needed or if it is is my diagram wrong
The Ball and spring is in the "T" but i dont see how the dial controles it... and is the T actually needed, can i just need run the controller between the wastegate and turbo housing?
Normaly i can look at these things and figure them out, but if connected them up on the bench and ran a foot pump to the controller and some hoses with a gauge to see what happens.
i can controll using just the controller, buti can make any changes in pressure using the T?
Please Help!!
« Last Edit: 30 September 2014, 01:19 by TETSUOXGEZ »
Offline Dalo Harkin
Re: MBC Install - somthing doesnt look right
« Reply #1 on: 30 September 2014, 08:25 »
why are you wanting to run an MBC in the first place?
Offline TETSUOXGEZ
« Reply #2 on: 30 September 2014, 10:01 »
I need to mkae sure the N75 hasnt died.... so this was supposed to be a quick plumbin and test to see if i get the same reults or if the boost holds steady, if steady then i know the N75 needs replacing.
I need to fix this quick as its booked in at R-Tech on th 7th for a stage 1
Ta
Al
Offline Dalo Harkin
« Reply #3 on: 30 September 2014, 12:12 »
be quicker to get someone local to swap an N75 with for 10 minutes, and cheaper.
If the N75 was faulty you would have a fault code
Offline TETSUOXGEZ
« Reply #4 on: 30 September 2014, 12:39 »
I would, if i had someone to swap one with... :wink:
dont know any GTi owners yet near me who are friendly
Offline davidgtrr34
« Reply #5 on: 30 September 2014, 12:49 »
Yes that is the correct setup. Also a faulty n75 doesn't always give a fault code. If you set the MBC too high your  car will keep hitting limp mode
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 30 September 2014, 18:38 »
or worst case go pop
Offline barrym381
« Reply #7 on: 30 September 2014, 18:43 »
this is why a never let revo near my car as they wanted 1 fitted before mapping it  :grin: nick and ben @ r-tech had a wee laugh about that idea
Offline Dalo Harkin
« Reply #8 on: 03 October 2014, 12:28 »
I'm not a million miles away if your ever near Stockport.
If its faulty you will know as soon as you fit another that isn't  :grin:
Offline TETSUOXGEZ
« Reply #9 on: 04 October 2014, 20:22 »
Dude, that would have been cool... but my N75J has arrived :)
and i found that with heatsoak the valve was sticking and a blown breather pipe allowing in air pass the MAP... All sortedand she runns like a beast :D
so ool, ive even boughter her a new badge "The Interceptor" and after Tuesdays trip to R-Tec she truely will be...
I have such big plans for her, she will eat Ford's, Mig's and Scoobys for breakfast
Also gave up with the MBC as i could not get the damn thing to regulate boost, no matter how or where i installed it :/
