Author Topic: 1.8T Oil Leak  (Read 2602 times)
Offline Scott D
1.8T Oil Leak
« on: 30 September 2014, 00:27 »
Got a slight oil leak that is only apparent after a long run or when giving it some stick. It's leaking from near side of block from top on to the gearbox when and can smell it burning when leaking.
Could this be rocker cover gasket or oil to turbo line?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline MarcIV
  • Mk4 GTI
Re: 1.8T Oil Leak
« Reply #1 on: 14 December 2014, 21:58 »
Sounds like it could maybe be a gasket
Flash Red Mk4 golf 1.8t GTI :)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: 1.8T Oil Leak
« Reply #2 on: 15 December 2014, 10:57 »
Likely to be the cam chain tensioner gasket given your description. Usually seeps from the 'half moon' rubber part and should be able to see this to confirm.
Re: 1.8T Oil Leak
« Reply #3 on: 18 December 2014, 22:05 »
Give it a good clean up then run it up to temp, you will soon see where it is leaking
