Author Topic: ABS light  (Read 10127 times)
Offline 1 gti
ABS light
« on: 28 September 2014, 10:31 »
Having trouble with my ABS light and system. It first started with abs light and red handbrake light coming on flashing and beeping!! Turned engine off and back on and it would clear. The other day whilst braking lightly my abs came light came on and could feel it under the pedal. The abs light comes and goes which I find strange. I've used vag-com and the code is 18057 power train date bus and the other code is 01316 abs control module, no communications. Is my abs unit screwed? I've checked fuses on top of the battery and are all ok. Any help would be appreciated. Cheers
Offline Mk2_tel
Re: ABS light
« Reply #1 on: 02 October 2014, 06:43 »
I had a similar problem changed both front abs sensors
And my brake fluid cap/sensor £13 roughly from vw
I changed the cap due to the handbrake light keep popping up flashing
