Author Topic: 2.0 8v oil problem  (Read 4956 times)
Offline Craigwilson
2.0 8v oil problem
« on: 28 September 2014, 00:12 »
hi all
so today i finished my 2.0 8v conversion to my golf using the 2.0 mk3 block and the 8v digifant head
the car started first time however there is no oil getting to the head, or very very little at best, the oil light stays on and no oil comes out the side where the pressure sender goes, it does come out under good pressure from the sender at the filter housing tho.
anyone had this, seen it or know anything about this as i am rather stumped.
cheers.
Offline Santiago
Re: 2.0 8v oil problem
« Reply #1 on: 28 September 2014, 07:53 »
Any chance you've got the head gasket on upside down?
VW BUSH
« Reply #2 on: 28 September 2014, 10:53 »
Check the pick up is not blocked or fallen off in the sump.
Check the pump works.
Head gasket upside down would be a first for me and a major fail. Hows the coolant as this would be messed up too.
Offline Craigwilson
« Reply #3 on: 28 September 2014, 11:20 »
the head gaskit is on correctly because knowing I was using a block and head that came from different cars I checked and double checked that everything lined up and all the holes matched. I'll pull the sump off today and have a look in there, I'm using yhe mk2 oil pump (assuming there the same). my distributer Doesbt seem to be sitting correctly tho and I know that's what drives the pump, it sticks out more than it should
Offline ians
« Reply #4 on: 28 September 2014, 12:36 »
What dizzy are you using? As the original mk2 one wont fit?
Offline Craigwilson
« Reply #5 on: 28 September 2014, 13:29 »
the mk3 body with the mk2 internals, just sorted that, the gear was on upside down
Offline Craigwilson
« Reply #6 on: 28 September 2014, 17:37 »
is the mk3 oil filter housing different ?
Offline Santiago
« Reply #7 on: 28 September 2014, 18:30 »
Don't suppose you took any pictures of the re-assembly process, the new gasket particularly?
Offline Craigwilson
« Reply #8 on: 28 September 2014, 20:51 »
I didnt no, my problem lies with the oil cooler mount thingy, I put my airline back through the head sender hole and air cam out there's nithubg getting to the head because Theres nothing pumping it in that direction
Offline Santiago
« Reply #9 on: 28 September 2014, 20:59 »
Where did the air come out when you did that? At the filter housing?
