Author Topic: Brake pad wear indicator etc  (Read 2152 times)
Offline Jammy1
« on: 26 September 2014, 10:38 »
Hi All
On my previous BMW and the Wife's Mini there are a range of service items that count down.  One example is the front and rear brake pads.  You'd basically get a 'miles left' countdown to when they need changing. There was also this feature for brake fluid and the other service elements.  Unless I'm being really stupid, possible, I can only see the countdown for the oil change and inspection services.  Is there any more detail hidden elsewhere?
PS
I'm of the long life service regime.
Thanks.
James.
Golf GTD, Tornado Red, 5dr, Manual, High Beam Assist, Park Assist, Keyless and Winter Pack.  Ordered 15/03/14.  Estimated BW22. Confirmed BW25.  Collected 17/07/14.
Offline KyleB
Re: Brake pad wear indicator etc
« Reply #1 on: 26 September 2014, 10:42 »
It will let you know when your tyre pressures are low and also when you're about to run out of washer fluid. I'm not sure about brake pads though.
Offline mcmaddy
« Reply #2 on: 26 September 2014, 17:43 »
It's got brake pad wear sensors that will produce a warning light on the dash. It won't however tell you how many miles you have left on your brakes and I'm not entirely sure how BMW manage this.
