Author Topic: Iphone 6 + golf Bluetooth doesnt work  (Read 8300 times)
Offline iandjm
« on: 19 September 2014, 21:48 »
Hi. I just knew something would go wrong. I have a new iPhone 6 which I am able to connect to the car Bluetooth and sync contacts etc. one problem though the signal strength and carrier info does not seem to be transferring between the phone and head unit. Ie it says no signal all the time. I am able to start a call from the car but after a short time the Bluetooth disconnects with the message no network connection although the phone continues in the call, just not connected to the car. I guess the new iPhone uses differnt incompatible Bluetooth? I have an iPhone 5 on iOS 8 which is fine so can rule out the os. Help!
2017 MY Golf R 3dr DSG | Lapiz Blue | Dynaudio | Heated Screen | Advanced Phone | Sat Nav | Winter Pack
Offline Jammy1
Re: Iphone 6 + golf Bluetooth doesnt work
« Reply #1 on: 19 September 2014, 22:41 »
Can't help I'm afraid but my iPhone 6 works fine on EE.  Haven't tried to make any calls to be fair but the signal strength seems to display correctly.  I'll have a play tomorrow.
PS
The carrier details, EE, also displays.
« Last Edit: 19 September 2014, 22:43 by Jammy1 »
Golf GTD, Tornado Red, 5dr, Manual, High Beam Assist, Park Assist, Keyless and Winter Pack.  Ordered 15/03/14.  Estimated BW22. Confirmed BW25.  Collected 17/07/14.
Offline iandjm
« Reply #2 on: 19 September 2014, 22:56 »
I guess that rules out the car though as I assume the Bluetooth modules will be the same. Thanks
« Last Edit: 19 September 2014, 23:00 by iandjm »
Offline mk7gti
« Reply #3 on: 20 September 2014, 08:10 »
I hope it's not a major issue I will be picking up a new iPhone in a few weeks and I'd hate to lose the hands free kit.
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
Offline iandjm
« Reply #4 on: 20 September 2014, 09:59 »
Hi. I got it working after 3 hours. Reset and reinstalled ios and reset car Bluetooth completely it finally works. Phew!  A tip for anyone having problems with their iPhone is to remove as many iMessage numbers as possible from the device. Seems to cause Bluetooth problems.
Offline Mrf
« Reply #5 on: 20 September 2014, 10:25 »
hi
I love the fact my 5 slots in the lower dashboard cubby hole on its side, with lightnighting adaptor mdi plugged in, and i can use google sat nav, and all looks like built in car.
can you please check that the 6 fits in the space, before i order the 6
thanks
Ian
Offline iandjm
« Reply #6 on: 20 September 2014, 10:36 »
Will do when I'm home later :)
Offline AlanH
« Reply #7 on: 20 September 2014, 22:18 »
Second post on this page:
http://www.golfmk7.com/forums/showthread.php?t=4731&highlight=iPhone&page=5
Seems that it fits, but only just!
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline iandjm
« Reply #8 on: 21 September 2014, 02:56 »
Hi,
Yes it just fits.  It will be v tight with the lead in.
Ian
Offline Mrf
« Reply #9 on: 21 September 2014, 08:52 »
many thanks..I did manage to try it last night...very tight...but can do it :smiley:
thanks again
