Author Topic: mk3 golf not starting  (Read 4814 times)
Offline xXAHXx112
« on: 17 September 2014, 19:59 »
had my mark 3 golf a little over 4 months now and never missed a beat. was driving home a few days ago when the engine just stopped revving, kept pressing the throttle and nothing happened. stopped in lay by and car cut out, managed to get it going again and got it home but now it wont start at all, had a look at the HT leads, the rotor arm and spark plugs but they are all fine. anyone any ideas?
The day i drive a vauxhall is .. doesnt matter, wont happen
Offline madmanmart
Re: mk3 golf not starting
« Reply #1 on: 17 September 2014, 22:20 »
Has it got spark, if not then check the coil.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline xXAHXx112
« Reply #2 on: 18 September 2014, 18:55 »
its got a spark, looked at the coil too :/ .. im stumped
roberto
« Reply #3 on: 18 September 2014, 20:16 »
what model of mk3 is it?
Offline itavaltalainen
« Reply #4 on: 18 September 2014, 23:55 »
yeah, that'd be really good to know...
engine code please...  :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 19 September 2014, 06:58 »
Checked the fuel pump and ecu relays? When you turn the ignition on can u hear a whining noise (fuel pump)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline xXAHXx112
« Reply #6 on: 19 September 2014, 20:09 »
you know what, i havent no .. dont hear anything except it coughing :( .. as for the engine code, its a bit dark! will get it tomorrow!
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 20 September 2014, 08:30 »
Turn ignition on and listen for the whine noise. That will be the fuel pump priming
*****MK4 GTI T*****
Offline xXAHXx112
« Reply #8 on: 22 September 2014, 19:23 »
right, got it started!! will run for about 5 - 10 mins and then cut out again, rev counter will hit zero while engine still running, and the oil and battery light will flash at me .. been told it might be the engine speed sensor? is that right?
« Reply #9 on: 22 September 2014, 20:01 »
Yes it might be the hall sender, but that will only stop it running on engines that don't have a crank sensor as well, so spit out the engine code already?!
with engine code I can also tell you correct part number and possibly give you instructions on how to change it ;)
